Outlaw Street
http://outlawstreet.co.uk/
Clutching at straws
http://outlawstreet.co.uk/viewtopic.php?f=11&t=2524
Page 2 of 3
Author:  bmKen [ January 24th, 2015, 10:17 am ]
Post subject:  Re: Clutching at straws
Someone needs a dual plate clutch by sounds of it lol. Good luck john. Its sounding like your gonna end up looking for a different bigger gear box which is extreme
Author:  The Silver Surfer [ January 24th, 2015, 2:22 pm ]
No room for another box Ken, they had to move the battery under the passenger seat and tip it on it's side to get the engine and box in.
Author:  bmKen [ January 24th, 2015, 3:17 pm ]
Sounds right, I had a rover with a Peugeot engine in it many years ago and it was horrible to drive lol, manufacturers who buy in engines never really work it out properly. Maybe a silly question but do u use a controller on the gas?
Author:  The Silver Surfer [ January 24th, 2015, 6:23 pm ]
The system is now all WoN apart from the Holley Sniper bottle. Pulsoid controlled by WoN Maximiser. That is triggered by a throttle position switch as the Van is fly by wire. I did have a microswitch on the pedal but it took me a season to find that I could operate it every time by hand, but a foot pushes the pedal sideways and off the switch! I even thought that it was duff nos and I had been sold a tank of air. Steve Wood tested the nos and said it was ok.
Author:  The Silver Surfer [ February 4th, 2015, 8:51 pm ]
Image Just got to get it fitted now. You can see how much is taken out of the flywheel to get it all in to a small space. Top hat is more like a flat cap, about 45 mm fingers to face. Friction is a kevlar mix.
Author:  wakesupremo [ February 5th, 2015, 7:58 am ]
lets hope it sorts out the issues John. I would have expected to see a paddle clutch plate with all the torque you have being put through it.
Author:  The Silver Surfer [ February 5th, 2015, 9:18 am ]
I think if I upped the ante anymore, then it would have to be a paddle. But, after a talk at http://www.clutch-specialists.co.uk/info-which-clutch, as it is used as a van (pitbike transporter) and 2nd car occasionally, try it at this set up as it will never be trailered to a race. Never know about coming back :oops: .
I can't find any part numbers anywhere. I do know that it is the same sort of Sprinter SMF that I run at the moment but with a bit of machining to take the cover. The pressure plate is a Competition Clutch V6 VW stage 2 or 3. All that is on the friction is Sachs but they don't make a 26 spline centre, so that is made up as well. 500 mile running in should take me to OS1.
Author:  The Silver Surfer [ February 14th, 2015, 9:53 pm ]
It's in and running, pedal is a bit low but I can select gears no problem. May need a spacer behind the concentric slave cylinder, but I will get some miles in first.
The old (3500 miles) csc was broken and had to be replaced. That was un-noticeable though. :?:
Running in now, please pass if you can :lol:
Author:  wakesupremo [ February 15th, 2015, 9:41 am ]
Good to hear mate. That's a tad closer than Toms. We still haven't got an engine back from the builders yet.
Author:  The Silver Surfer [ February 15th, 2015, 10:30 pm ]
Still can't understand why it needs 500 mile break in on the clutch. I may lengthen the clutch pedal rod by 1 or 2 mm as that will bring the biting point up. Problem is swapping between two PTs, they are getting more different every move I make. Soon be totally different to drive :roll:
Page 2 of 3 All times are UTC [ DST ]
Powered by phpBB® Forum Software © phpBB Group
http://www.phpbb.com/
