Post new topic Reply to topic  [ 5 posts ]
 Post Posted: January 7th, 2017, 12:56 pm
Sooo, come on what are you all spannering on, share those pics of what the new 'master plan' is for 2017, whether it be an oil filter & plugs or a full out rebuild....
 Post Posted: January 7th, 2017, 8:01 pm
Tin worm had the capri rear chassis legs so u may or may not no ive sent her to ron at insane crations to get bk end sorted with a shorternd rear axle and 8.50 taged rolecage
 Post Posted: January 10th, 2017, 12:21 pm
I'll be fitting a sturdy upper control arm, drive shaft loop, and a set of Racestars - looking for some 275/60/15 rubber to match them.
OS-25
2010 Mustang GT 5spd
 Post Posted: January 10th, 2017, 5:49 pm
Not much going on, have bought a Holley dominator carb. should liven her up a bit....
 Post Posted: April 10th, 2017, 10:19 pm
hi all the capri still at insane creations so far bk end all cut out and tube ready to go bk inn bubble rear arches have gone so wheels will be were ford intended and tucked under the arches :D
