Post new topic Reply to topic  [ 11 posts ]  Go to page 1, 2  Next
 Post subject: holley help
 Post Posted: June 3rd, 2013, 12:51 pm
hi guys ive just striped me holley 650dp has base plate cracked and i was leaning out got a base plate on order so thats coverd me jets are.
jet with power thing are 67 the other is78 what size can i go up to next and can i fit the 78 jet in the 67 jet and up grad the one side or dont it work like that never striped a holley :-)
 Post subject: Re: holley help
 Post Posted: June 3rd, 2013, 1:14 pm
This link will help you understand the basics:-
http://www.bob2000.com/carb.htm
Good Luck ;)
 Post Posted: June 3rd, 2013, 1:15 pm
Good Luck ;)
thank you
 Post Posted: June 3rd, 2013, 2:25 pm
got to go too stages up on the jets so has any one got any jets they wont to sell :-)
 Post Posted: June 3rd, 2013, 10:31 pm
best to get a jet pack that way you can experiment at the track until you get the best combo got mine from summit think it was around $50 plus delivery
 Post Posted: June 3rd, 2013, 11:07 pm
ok thank you ive got a summit catalogue i will take a look
 Post Posted: June 4th, 2013, 9:01 pm
https://www.google.co.uk/url?sa=t&rct=j ... 44034,d.ZW
bin on this web page and ive got primmary jets 67, secondrary jets 78, power valve 6.5 primary nozzle 28, secondary nozzle 28
but beens i leaned out may be because of cracked base plate lol,
do u think its worth buying a pair of 69 jets and a secondary nozzle 31 same as a holly 700 double pump :D
4778-3,4,5,6,7 700cfm
Primary main jets 69, Secondary main jets 78, Power valve 6.5, Primary Nozzle 28, Secondary Nozzle 31
 Post Posted: June 4th, 2013, 10:31 pm
Did you repair the baseplate or are we talking about another carb.
 Post Posted: June 4th, 2013, 10:33 pm
its a good starting point. as a rule of thumb i tend to go up or down no more than 2 jet sizes at a time that way your not making to much of a jump from your base line, that way you should make a difference but not go to far the wrong way . also keep a note of what you've tried and what differences its made . what sort of rpm are you shifting at/revving to as this has a big impact on what size carb you run verses engine size
 Post Posted: June 4th, 2013, 10:57 pm
brought another 650 double pump and tuke base plate off :D
