Post new topic Reply to topic  [ 11 posts ]  Go to page Previous  1, 2
 Post subject: Re: holley help
 Post Posted: June 4th, 2013, 11:02 pm
nightmaresracing wrote:
its a good starting point. as a rule of thumb i tend to go up or down no more than 2 jet sizes at a time that way your not making to much of a jump from your base line, that way you should make a difference but not go to far the wrong way . also keep a note of what you've tried and what differences its made . what sort of rpm are you shifting at/revving to as this has a big impact on what size carb you run verses engine size
im shifting at 5000 in 1st to 2nd 6000 2nd to 3rd then i hit 4500/5000 ish and she falls down as if no more power or fuel to power her i no base plate was cracked after a couple of outlaws had a look for me :)
so thinking of buying jets leaveing as is with new base plate run and see if she drops off again
