Post new topic Reply to topic  [ 9 posts ]
 Post Posted: August 23rd, 2013, 10:33 pm
What's people's verdicts?
Looks far worse than just a head gasket to me...
It's a diesel peugeot van (or at least it was), an yes all of that oil is coming out of the rad expansion tank.
 Post Posted: August 24th, 2013, 12:24 am
Yep deffo looks screwed
 Post Posted: August 24th, 2013, 7:12 am
Maybe it's a new type of antifreeze :D :D Dead as a hammer.
 Post Posted: August 24th, 2013, 8:29 am
Sorry to say this mate but I think you've got a slight bit of lower crank case pressure pushing oil into the water ways. Maybe if you substitute the coolant for oil it'll just keep circulating it!!! Or maybe its scrap now.
 Post Posted: August 24th, 2013, 7:20 pm
Just looks like the oil to water cooler needs replacing
 Post Posted: August 25th, 2013, 8:16 pm
Do you reckon so George as I'd have liked to have saved the old van
 Post Posted: August 25th, 2013, 8:23 pm
Very common on the diesels,, they use oil to water coolers and they leak from the oil side to the water system,, does it run fine apart from that,,, can be a real bitch to get out
 Post Posted: August 25th, 2013, 9:27 pm
Yep it was running fine haven't run it since discovery due to oil loss
 Post Posted: August 31st, 2013, 10:49 am
An the post mortem is in........ it's proper dead.. head gasket gone plus done a valve...
So a call to Steptoe An Son is needed as it's not an economical rebuild based on age an condition of the old girl...
