Post new topic Reply to topic  [ 9 posts ]
 Post subject: rear axel
 Post Posted: August 24th, 2013, 8:54 pm
hi guys ive sqared and set my pinon angle on my axel it was set sqare as 167 drive car bk from work shop got home and it was 167 pasanger side 168 driverz then when i jacked car up by diff so both wheels are off floor droped it down again and i was left 167 and half on drivers i dont under stand y its moveing as im useing ladder bars on a welded axel. the only polley bush is on me panhard rod any ideas or is it becase everything had too reset cheers
 Post subject: Re: rear axel
 Post Posted: August 24th, 2013, 11:23 pm
168 what,, inches, degrees
 Post Posted: August 25th, 2013, 1:22 pm
168 inchs mate i think im twisting me chassis has i have a big tyers so i dont get rear skip bonce or tyre squel plus when i jack car up the rear wheels they skid has they unwind looks like i need a lsd
 Post Posted: August 25th, 2013, 2:04 pm
I would check all the welds etc, a ladder bar system can only move fore and aft if something is broken in the mounting system
 Post Posted: August 25th, 2013, 4:07 pm
hi ive cheeked all welds looked at floor for sighns of cracks ripples etc and nothing ive fully welded the 3x2 box section to rear chassis and front chassis then i stiched welded the orangle chassis for sum strengh so if im pre loading me axel badly the rest must be flexing body or chassis obly prob metal only moves so much and comes bk so much and my tyres have such a foot print sumthing is going to brake at most so looks like i need a lsd to fit a volvo 940 axel
 Post Posted: August 25th, 2013, 8:26 pm
Does this thing have a cage in it,, a proper welded in cage
 Post Posted: August 26th, 2013, 10:14 am
no mate no cage
 Post Posted: August 26th, 2013, 10:18 pm
If you don't have a full cage what is stopping the chassis from flexing,, what are the rear frame rails made of,,3x2.....
Do the ladder bars run onto a proper crossmember..
If the rear is moving about on a fairly gentle drive my advice would be to not use the car, the movement at full acceleration could move it far enough to break, and that could be painful for either yourself or a fellow racer...
 Post Posted: August 26th, 2013, 10:48 pm
its all good i reset alinment went for a big drive and nothing moved which means the bloody bloke who set it up for me fooked up so well happy now and panic over just got to xplane to wife ive orderd a roll cage lol cheers for the help
